wolfy
- Mar 12, 2006
Can you check the voltages out of the tranny?
Originally Posted by wolfy Can you check the voltages out of the tranny? |
Originally Posted by shlomomofo sam- you used the higher voltage aerovox caps? i noticed that yours have both leads on one side. is there any reason to think they would sound different? just curious... |
Any non-polar cap will have both a DC and an AC rating, though they usually only state one, and which they state is usually determined by where the cap will generally be used. To figure out the other rating, multiple an AC rating by 1.414, or divide a DC rating by 1.414. my guess is that the DAC-AH doesn't have any voltages higher than 30V or so, so I am sure your Aerovox caps are fine. |
...either time or placebo has restored some of the bass. |
Originally Posted by Samgotit That was fast. I didn't have a chance to order yet. Borrow an old welding helment, power up the DAC, and let us know what you think! BTW, I believe it is the dropout voltage from the regulator that's giving us 6v at the DACs. Maybe its time for a LM7809 or LM7810? Take Care, Sam |
Originally Posted by dsavitsk The 7808 shoud put out 8V. The dropout V is 2V meaning that so long as the input V is 10V or higher, everything should be fine. I have no idea why you only have 6V ... have you tried using a different meter or changing the meter's batteries? |
