kipman725
- Nov 6, 2006
I would agree with the new PSU and a new output stage (although not valve based as it would cost far too much on this DAC to be worth it).
The capacitors and especially the resistor replacing I would not do however as it already uses metal film resistors and the so called "audiophile" capacitors are mostly fancy packaging and pseudo science and should be avoided like the plague. I mean this site plain lies in many places:
http://www.acoustic-dimension.com/blackgate/bgmain.htm
Also how do you measure "transparency"? and as far as I know presence is a type of treble boosting filter... which black gates are not.
some of the other comments.. fancy paper and plugs?!?!? seriously what planet are you on.. the case of this thing is thick aluminium which blocks RFI far better than that fancy paper. As for the plugs the current ones make perfectly good contact, what is there to be improved there?
It annoys me when people peddle expensive crap like that; these companies are out there to rip you off, don't you see that?
Originally Posted by jbloudg20 /img/forum/go_quote.gif Here are my suggestions: Build a STEPS for 5 volt operation. Disconnect the power bus from the input, and run the entire DAC board from your new PSU. Optionally build a thread for variable operation (say 5 or 12 volt, or even up to 24), and dissconnect the opamp power pins from the board, then use the new PSU to power your opamps. Now you have more versatility in the opamps you choose. Depending on the circuit topology: OPA627 in sockets at 24 volts. Replace all the electrolytics with better quality. (blackgate in signal path, etc.) Replace all resistors after the gain stage (or if you feel happy, replace all resistors in the signal path) with kiwames. Here are the over the top suggestions: In addition to the above mentioned: Disconenct the line out. Take the output from the DAC, and run it to your new 5687 tube buffer stage. Output from the buffer stage goes to your line out. It would be best to remove the DAC board from teh chasis and rebuild inside your own. Hey you didn't specify a budget, so I just kept going. |
