Yea the M50x are recommended ALOT. Aside from a few people, even the guy at Z reviews liked cheaper cans better.
I just want to make myself 100% clear on listening to the Z review headphones reviews.
I never said base everything off of that. I get discouraged when everyone focuses on 1 thing I suggest when you / anyone can clearly make up their own conclusions based on other media.
It's like you forgot I mentioned going back and forth with my DT 770's on the same exact material.(FLAC MP3, Games) That part is never mentioned for some reason. I did NOT base my decision based on Z reviews only. I only took advice from him about comfort and sound but I looked to head-fi as well. When a guy with $500+ headphones...whatever Mad Dogs says that the Takstar 2050 were a close second to those...then says the pro 80's are basically the closed version....that pretty much sold me on it. But... his review of the DT 770's weren't that accurate to me because I have them and the HSR sound way better to me. Unless headphones lose their high frequencies over time...mine were never that bright. Good clarity, but not much forward vocals...almost recessed in soundstage. (Compared to the HSR1000) I actually cannot believe how good the HSR's sound. It makes no sense. They should not sound better than DT 770's.
Vocals do indeed come alive in the Pro 80's/HSR1000 more so than in almost any headphone I've heard. The 598's sounded pretty good as well but they had no bass at the store I was listening to them on. I wouldn't mind owning a pair just for fun though because I think they might be a tad more comfy than the stock pads on the tak pro 80s... although soon they will be HM5 pads. Then I'll truly be able to judge the comfort level. I still can wear these things for hours though....easily all night after like a 10-15 min break.
You're misunderstanding. He is only trying to state that your recommendation of listening to youtube videos is actually a mistake to make. An audio auditioning of online videos to compare two headphones IN A VIDEO is a mistake in itself. Now, if you own two headphones and try to compare the sound in a youtube video or your flac, mp3, games, then that's a different story.
You should not have suggested youtube as the sound quality is terrible to compare with A set of speakers or ONE headphone, especially the headphones you don't own in the video. You could have avoided a misunderstanding if you only recommended to hear zeospantera's review of the headphones alone.
Easiest recommendation, go and audition them by buying the takstar pro 80 AND the m50xs on amazon. Of course, he has to save a little more money, but then he can return the headphones that disappoint him.
No one is bashing on the takstar pro 80, I mean heck, even this thread (which you should have recommended along with zeospantera's video) http://www.head-fi.org/t/684159/chinese-asian-brand-info-thread-headphones-iems-amps-dacs
and
http://www.head-fi.org/t/585356/the-takstar-technical-pro-gemini-greathon-cyberx-qpad-thread
to help him read the comments of many reviewers (for the skeptics anyway).
All of what I stated above would have stopped the confusion.
