gpalmer
We are the weird ones.
- Apr 27, 2002
Oh man, now I have a bunch of home work to do! I appreciate the huge head start all of your posts have given me. Normally I would have spent a few months really learning about each of the players and the portable market in general but in this case I wanted to short cut the process a bit and your input will really help there.
I already have a portable CD/DVD/DVD-Audio player that will be going along for the trip so this would just be for digital audio so I think the laptop might be overkill. If I take one along it'll be property of the company I'm working for.
It's looking like the easiest and cheapest amp to bring along would be my Grace 901 since all I have to do to convert it to 240 V is change a cam setting, pop in a new fuse and get a new power cord. (Thanks for the 240 V tip Bangraman). This does have a built in DAC on it which I haven't played with a lot but it seemed pretty good to me when I did try it. OTOH, it might make more sense to get something that could be used at work as well as home. I've never liked taking the Grace to work since it just costs too durn much if it gets damaged, lost or stolen. I have to have a debate with myself over whether I want to get an XP-7, get a UK version of the Elpac for my Gilmore Lite or try something different like the Bithead.
This means that the suggestions I need to look at are:
iPod - Defnitely of interest, I just wish I could get a bigger drive for it though if Apple's lossless compression is as good as they say, I think this could work out nicely.
NJB3 - Another really strong contender. I took a look at the drive upgrade process and that would really make this an interesting player. Seems like a lot of folks think very highly of this one in spite of it's clunky looks!
I assume the hot setup here is to buy the 20GB, rip out the drive and put in a 80 GB replacement. Is there any advantage to getting the 5400 RPM/8 MB buffer models that are out there? Are there any disc intensive activites that get performed other than loading it, like a defrag or a disc integrity check? It looks like Creative is killing this player off since it isn't for sale on thier web site anymore, though I'm not sure this is of concern. Can anyone tell me what the interface is for the stock hard drive, that is, is it ATA-6, ATA/100, etc?
Rio Karma - This is another good one I have to look at more closely.
IHP-120 - If the Grace comes along for the trip I'll have a DAC on hand so this might be worthwhile. How does the built in DAC compare? I would like to have first rate sound even without an external DAC.
One question that popped out at me while I was researching the players was about recharging them.
1) Does the iPod recharge even while it's in use?
2) Does the Jukebox 3 take a standard AC adapter that I could pick up in Great Britain?
