gpalmer
We are the weird ones.
- Apr 27, 2002
Hi, I'm hoping to cut through the red tape and get a quick idea of what portable players to consider along with a quick recomendation for ripping software.
It looks like I might be out of the country for a couple months. I will not be able to transport my CDs along with me so I would like to take my music along in some sort of a digital player. I assume this means a hard disc player with a capacity of around 60 GB though if I've missed a better alterntaive please feel free to point it out. I will probably be using this player in a mostly stationary role, carry to work, carry back to hotel, rinse, lather, repeat so size and weight are not really major factors. i will probably be using the player with either an HR-2 or a Gilmore V2 (although this might finally be the justification for getting the XP-7 I've been waiting for) and a PS-1 or Etymotic so I'm looking for the best source I can get my hands on. I think I have about 350 CDs to fit on the player. Here are my questions:
1) What is the best source player to get? Am I looking for a portable or is there something else that would be small enough to use and have higher quality sound? I'm not too concerned about the size and weight so much as the quality of the output, ideally it would be worthy of the Gilmore V2/HR-2/XP-7.
2) What would you recommend as the best way to rip the CD audio so as to get the audio on the player with the highest quality?
