Originally Posted by beez /img/forum/go_quote.gif
thanks a lot for the response, larry. i was kinda hoping you'd chime in at some point with some advice. i actually just completed a purchase for a keces 151 DAC, the price was right and it's gotten some solid reviews around here. so i think now i'll just have to look into an amp. any advice on which tube amp would go nicely with the keces and rs-1? i'll probably be holding off for maybe a month or so at least before i can spring for the amp, but i'll probably be looking at around $500 or so. did i make a good choice with the keces? it was $200 shipped.
I have heard good things about the Keces, just haven't heard one. Amps that I have heard and really like with Grados in order of price include the:
Millett Starving Student ($100-200 depending on build yourself or not),
Head-Direct EF1 ($299-399 depending when on sale),
TTVJ Portable Millett Hybrid ($450),
Woo WA6 ($585 - $1200 depending on mods),
Melos SHA Gold (discontinued, $1500-1800 used)
Zana Deux ($1800-$2200 used, not sure new)
In your price range I would look at the EF1 or TTVJ, and if you get the Woo you at least should add the $110 pseudo dual power supply to the $585 base price, and later add a Sophia Princess rectifier for $150.
The TTVJ has crazy synergy with every Grado I have tried on it, just with a little less detail than the Woo or higher level amps, and the soundstage is slightly bigger than the EF1, while the maxed Woo is even above that. I haven't spent enough time with my son's Millett Starving Student amp to compare to the other amps, other than to know it was like heaven with Blutarsky's Grado PS-1 at the 11/1 colorado head-fi meet. None of these will disappoint.
