MonkeysAteMe
- Oct 6, 2006
Is there a really thorough writeup for a DAC that a complete noob at electronics could follow? I can't read schematics and stuff. Thanks.
Originally Posted by MisterX Sounds like this inexpensive "half kit" from US Hi-FiDIY site would be perfect for you. http://us.hifidiy.net/Article.asp?ArticleId=174 I call it a "half kit" because you will need to supply a case, IO jacks and a power supply. The only tricky part is soldering the smd CS8414 chip and even that is pretty easy. (it took me less then 2 hours to build one with a tread PSU in a hammond case) |
Originally Posted by rreynol I just ordered one of their "extreme TDA1543" kits. Seemed like a pretty neat DAC project. |
Originally Posted by MisterX Did you order the case as well? $55 is kinda spendy but it does look like a nice case. If you are interested: Here is the Chinese link for the "upgrade module" http://shop.hifidiy.net/product/121.htm |
