I've only tried it with the test versions of a few of the CIEMs when I was in Tokyo. One thing I like about it, which I didn't expect, is that the gain switch (which only really puts a different resistor in the signal path) alters the frequency response of IEMs very slightly. This allows a tiny bit of fine tuning of the sound. The important thing though is, at least with the DX100 I own, I haven't had any hiss issues with sensitive IEMs, but you might want to read the DX100 threads, as not everyone has had zero issues.
Quote:For portability, I've been very happy with the DX100 and Sony XBA-3's. While I've found the top-of-the-line portable amps to be better than the amp in the DX100, they aren't, IMO, hundreds of dollars better for IEMs or the portable headphones I've tried with them. I save my crazy heavy portable rig for when I'm travelling, where it sits in my hotel/apartment/wherever on the table. It'd be more worth your while to put the majority of your $2k into a good pair of IEMs to use with one of the top-of-the-line DAPs. Part of the reason I suggest that is the better isolation good IEMs can provide.
Do you pair your DX100 with a pair of CIEMs? If so, which?
