Digital Gentleman
The right piece makes the buzzing noise when I touch the plate and only when plugged in to my laptop, when I plug them to my LG V30 there's no noise which gave me an initial relief. It's a slight noise but I can easily hear it and I think it comes from one of the BAs. I was thinking to get a cheap dac just to get rid of the quite noticeable hissing from my laptop anyways but the real question on my mind is "will this affect the lifespan of the piece?". I don't what causes it, the stock cable with mic?(mic is on the right so.. maybe?), conductivity between metal plate and drivers?, just my crappy laptop soundcard? What do you think? Should I return it to the local seller or should I keep it?
Your help is much appreciated.
