bigshot
That comment has nothing to do with EMI.
If you were just talking about grounding, the output of the UPS is grounded as well as the wall outlets I plugged directly into.That comment has nothing to do with EMI.
Do you also have a different DAC that you can try in this setup?
I'm just using the DAC portion.Do you really need to use a separate amp with E90?
Again, you'll have to excuse my ignorance, since I have no experience with e-stats. But I thought the E90 handled the amplification for your headphones? And I'm getting rather confused with all the different technology involved, ie energizers, transformers, amps and so on.
If you are double-amping, then maybe that's why you're getting some extra mains hum?
