Occy
- Sep 23, 2010
Hi all,
I recently got a new Sony Xperia XZ Premium, and when running it into my RSA Intruder DAC/Amp (via a standard 10cm USB-C to USB-2 cable) I'm getting a lot of GSM interference.
I prefer to run my portable setup as a stack, and I almost exclusively listen via Tidal which means I can't switch to Airplane Mode.
Would a shielded cable with a ferrite bead help? I can't find any available, but I am skilled enough to make one up if it'll help.
Otherwise is there anything else I can try?
(I did use the search function, but I couldn't find any sollutions)
Cheers!
Cheers!
