quadomatic
- Jul 30, 2008
I got my pair of AI-M6s. They're pretty good, but I'm having trouble fitting them on. The left one I'm able to get on pretty good and so I get good bass, but the bass ends up being stronger on the left than the right because of the fit. It gets painful...
Any advice on fitting on the AI-M6s?
UPDATE: nm, pulled back the hard plastically ring so that it was tight against my ears and secured the earbuds...bass is strong, mids and highs are so detailed....HEAVEN compared to my marshmallows.
