AndroidVageta
- Oct 19, 2010
Edit: I'm an idiot and saw the massive DON'T POST HELP at the top right as I hit post...mods remove if necessary just need a quick answer!
EDIT 2: Problem solved so no need for further advice unless you've just something to add for future possible search engine results lol! Thanks everyone!
Just put a new cable on my earbuds (soldered on) and they're out of phase. Normal 3.5mm unbalanced cable.
So...if I just swap the positive and negative wires on one said will this fix this? Does it matter I end up having, say, the negative wire on the positive terminal on the speaker and vice versa?
In other words, if the headphones aren't out of phase after I swap the wires around in one side is the problem fixed or does the positive/negative ends of the cable HAVE to go to the correct positive/negative terminals on the speakers?
