If you want even better highs though, there's also the C700/C751 (same phone, different accessories). It's more expensive,
but has better highs (at the expense of bass response, which is a bit weaker). |
You haven't heard the C700s, so I guess you're repeating what I said about them earlier?
The bass is not lacking in any department. Check the Denon thread to see what people say about it. It may be
weaker than the C551s (which I know, having used both of them) - but it doesn't detract at all. It's still very powerful.
If Koop wants a more balanced sound, then the C551 won't cut it, since the bass is louder than everything else, and
does overpower the high end, which is not very detailed in the first place (in stark comparison with the C700).
It depends if his priority is extra bass impact or extra treble detail/quality. I just wanted to clarify the C700s are not short on bass, not by a long shot.
Koop, the C551s won't disappoint you as an upgrade to the e2c. They're excellent for the price and nicely made with aluminium housing. My b/f listens to rock almost exclusively and is very happy with them. And he's a basshead through and through
