dsavitsk
MOT: ECP Audio
- Aug 3, 2003
yes but we arent talking about amps tuned to be current sources here; running on current drive, are we?
I was merely using it as an example of how mechanical and electrical damping both matter, which I was told above did not.
Anyhow, I think the black and white nature of this argument is pretty stupid. As are the ad hominem attacks. The "objectivists" are correct that measurements matter. They matter a lot. However, the problem is that they have not identified how measurements correlate with sound. There is a temptation to view THD, or IMD, or square wave response, or whatever as the end all and be all of amplifier quality. But, this is simply not the case. So, until they can more clearly identify how exactly measurements matter (did you know that dissonant signals are amplified in the brain stem, while consonant ones are attenuated? that the sound preceding a sound influences how it is processed, and that musical experience influences all of this? http://www.soc.northwestern.edu/brainvolts/publications.php ), and identify some that do, "good" objective measurements can at best be seen as a necessary, but not sufficient, condition for good sound.
Similarly, "subjectivists" need objective measurements as otherwise they are simply guessing. Correlating changes that produce improvements with objective standards is the essence of learning.
Most of us who design audio equipment are somewhere between these extremes. Yes, you need to measure it, but in the end, it needs to sound good, too.
Back to the point, we are not driving theoretical resistors -- these are dynamic systems. And, the damping of the speaker driver has a lot to do with what amplifier is appropriate for driving it. If you don't believe this, hook up a Krell power amp to a Lowther speaker some time. It will sound awful, and have no bass. This is not because either is bad, but because they are incompatible. And, the argument here is that the drivers in Grado headphones are more like Lowthers than other more traditional speakers, which is really not surprising. So, a little less damping seems to go a long way. And, to bring it full circle, Grados do great with high impedance, "transconductance" amplifiers.
