Help building Cmoy Headphone amp...
Jan 22, 2004 at 7:03 PM Thread Starter Post #1 of 7
Scorpio(DDMF)
I want to build the CMOY portable headphone amp, but I can’t seem to pass the “Parts” table
Can someone post partlist for this version of the amp ?
http://tangentsoft.net/audio/cmoy-tu...ayout-0150.pdf
THX
Jan 22, 2004 at 7:53 PM Post #2 of 7
Jan 22, 2004 at 8:37 PM Post #3 of 7
To get to the layout you must have seen the parts page. Which parts are you having trouble figuring out?
I used:
* 470uF 25v input caps
* 0.1uF full sized film cap
* 1k ohm for the gain (which is too much... 2-2.4K ohm would have been better IMO)
* All Vishay Dale resistors
* OPA2132PA op-amp (socketed... definitely)
* SPDT switch
* mint tin enclosure
I designed it to use 2 9v batteries (by using 25v input caps), but I didn't build it small enough to actually fit the two jacks, switch, LED, and two batteries. It takes some skill and practice to do that.
Jan 24, 2004 at 2:05 PM Post #4 of 7
I used:
* SPDT switch
My English isn't so good
(I'm from Serbia and Montenegro) so I didn't understand what the autor ment by "this cap is from the power supply, and this one isn't the same it's from the amp part" and so on..
I just wanted to get a simple partlist for this version of the amp like: c1 is 1200mF, C2 is 470mF etc.
Please post resistor, cap and other part values...
THX
Jan 24, 2004 at 6:07 PM Post #6 of 7
Ok here you go...
C1 & C2 470uF 35v
R1 & R4 10K ohm resistor
C1 0.1 uF 50+v full sized film cap.
*don't confuse the 470uF C1 with the 0.1uF C1* look here and pay attenetion to the 4th picture
R2 & R3 4.7k or 4.75K Ohm resistor
R2 100k ohm resistor
R3 2.0k ohm or 2.2k ohm resistor
*note* this is for gain. Higher the value of this resistor the less volume the amp will put out. *It resists more*
I like a gain of about 5 or 6 so any resistor between 2.5kohm and 2kohm will do nicely.
Does that help?
Jan 25, 2004 at 10:12 PM Post #7 of 7
Ok here you go...
C1 & C2 470uF 35v
Does that help?
Yes it does
THX
