incognitoedleon
- Aug 7, 2005
I just broke a small piece of the tip of the tube on my phono preamp (Bellari VP129 if it matters). This may be a very dumb question, but does the tip of have any structural importance? Could a cracked/damaged tube damage the amplifier? At the moment, it appears to function fine. I just would like to know if the tube should be replaced right away and if there's any risk in continuing to use it.
The type of tube it uses is a 7025/12AX7A seen here. That tinier glass part at the tip on the top is what I broke off.
