Hello help about my dt770 pro 80ohm
RJ Smooth
- Dec 2, 2012
- Messages
- 10
- Reaction score
- 0
Well, for starters, if you are running these headphones through an MP3 player, you won't be very happy because no MP3 player/ipod/iphone can run these headphones because they have 80 ohms of impedance. The max impedance headphones that MP3 players can run decently well would be about those with 40 ohms or so of impedance.You will need an amplifier to get these to run at peak performance because they need a lot of power to run. Secondly, you also have to let them break in because the drivers are stiff when they are used in a new condition.
Cheers,
RJ
Cheers,
RJ
Sound Quest
- Feb 19, 2013
- Messages
- 291
- Reaction score
- 30
"Bass I Love You", also isn't THAT bassy.
I was pretty underwelmed the first time I heard that track.
adamlr
- Aug 12, 2012
- Messages
- 1,007
- Reaction score
- 46
qualify what you say mate, when talking about things that are controversial, tell the op that a difference of opinions exists, dont make it out to be like its a well established fact.
granted, 80 ohms is a bit higher then usual for headphones, but beyers are very efficient, and i can use my pair, who are 250 ohms, from my phone and still get pretty loud. its simply not optimal, and wont give you the full potential that your cans are capable of, a simple portable amplifier will give you more than enough power, and as my personal experience, and popular belief goes - the dt770s scale up very well and the better your amplifier, the better your dt 770s will sound.
talking about "burn in" is just opening up a can of worms. lets just say alot of members believe it is vital, while many others will say its a fairy tail. some will say that one just needs to get used to a new headphones signature...
when i got my dt 770s, i was underwhelmed aswell. the reviews make them sound like super massive bass monsters, when in fact they are not. however, to quote a different forum member "they are very bass capable".
my advise to you is to get the best amplifier you can afford, and to download an equalizer. right now as im writing this post i have the bass boosted by about 13 db and my ears are vibrating
. when i first discovered the wonders of equalization, i boosted more than 20 db in the bass range and my dt 770s took it like a champ with no issues whatsoever. they can be just as bassy as you want them to be.
also, keep in mind that if the music your listening to has no bass line - no headphone in the world will make any difference.
Cheers,
RJ
Amorgan
- Aug 13, 2010
- Messages
- 396
- Reaction score
- 13
No headphone will sound good with onboard.
get a Digizoid
im using onboard sound...
get a Digizoid
Maker
- Jan 9, 2013
- Messages
- 113
- Reaction score
- 11
Try it out with Xonar DG, best choice for you, 30$ well performing soundcard (dac/amp)
adamlr
- Aug 12, 2012
- Messages
- 1,007
- Reaction score
- 46
i disagree. it depends on the onboard soundcard and i think an external amp can make a larger difference then an external dac.
a digizoid however, is a good idea. i have never tried one, but its been intriguing me for a while. in effect, its basically a hardware device with alot of eq settings, just bass boost specific settings (and its analog ofcourse). i dont know if it can be used a standalone amp though? i know most of its users in the "basshead club" thread recommend "double amping" with another amp. again, i have never tried it myself.
No headphone will sound good with onboard.![]()
get a Digizoid
xledruidx
- Jan 21, 2013
- Messages
- 124
- Reaction score
- 10
i dont got money for a hardware equalizer... coud you suggest me a "software" equalizer where i can boost the db
because these are 5-10db too low bass :/ i listen to alot bass heavy and also none bass songs and theyre good for all!! exept bass heavy like dubstep(i dont get this) booom feeling in my brain
so if u coud give me a software equalizer id love you forever!
Ohqualify what you say mate, when talking about things that are controversial, tell the op that a difference of opinions exists, dont make it out to be like its a well established fact.
my advise to you is to get the best amplifier you can afford, and to download an equalizer. right now as im writing this post i have the bass boosted by about 13 db and my ears are vibrating. when i first discovered the wonders of equalization, i boosted more than 20 db in the bass range and my dt 770s took it like a champ with no issues whatsoever. they can be just as bassy as you want them to be.![]()
Master Shake
- Nov 27, 2012
- Messages
- 150
- Reaction score
- 19
Im currently listening to mine through a fiio e7 (bass setting 3 no eq on computer) and there is plenty of bass, the song you said you listened really isnt that bassy, if you want to hear a ton of bass listen to ephixa's some wobbles, and get an amp.
xledruidx
- Jan 21, 2013
- Messages
- 124
- Reaction score
- 10
also i woud like to buy zo2 digizoid but its like 120dollars... and if i order 120dollars(and i cant even find it on ebay?) so if someone got a really cheap zo2 digizoid for sale, or knows an program equalizer tht woud be greatly apprechiated!
Master Shake
- Nov 27, 2012
- Messages
- 150
- Reaction score
- 19
Are you running pc or mac? if you are running pc get foobar2k and get the columns ui plugin and the graphic equalizer plugin. Also the amp is not just used for partial eq'ing, it powers the headphones properly, a dac also helps because on board sound usually sucks pretty hard.
xledruidx
- Jan 21, 2013
- Messages
- 124
- Reaction score
- 10
but i believe good headphones shoud sound good even without them :=) ill try foobar2k. but u can use it with youtube spotofy etc? i dont only use flac's
i know this i tried a dac its insanely niceAre you running pc or mac? if you are running pc get foobar2k and get the columns ui plugin and the graphic equalizer plugin. Also the amp is not just used for partial eq'ing, it powers the headphones properly, a dac also helps because on board sound usually sucks pretty hard.
Tsujigiri
- Jun 19, 2009
- Messages
- 1,163
- Reaction score
- 107
They certainly do have bass, but they aren't bass monsters. Give them a chance and listen to them for a while before dismissing them completely. I think like many here, you'll find that you gain quite a bit in the sound of audiophile headphones over bass monsters that you may not have noticed before.
xledruidx
- Jan 21, 2013
- Messages
- 124
- Reaction score
- 10
Hey its you again! thank for reccomending
these are good i can really hear sounds i never heard before with my other headphones
but i believe ill let them burn in with pink noise for 1week and if i dont like them then im selling for pro900
its just the bass its like jello.... loose and wobbly not tight i hope it gets tighter over time
Tsujigiri
- Jun 19, 2009
- Messages
- 1,163
- Reaction score
- 107
Yes, the Pro 900's are definitely better for that. Sorry to hear you're disappointed with some aspects of the DT770's. But I think you'll find that in this hobby preferences are pretty fluid, and what you initially think you like will usually be different from what you end up liking with more experience.
