So now you're not hearing hiss but you are hearing static? I'm confused, what about the hiss?
Well I just pulled my J3>Arrow>SE530 out to test more carefully. I plugged them in after my Grados and didnt play with the settings. I was hoping it would behave with any settings.
Volume J3 = 30
IMP = II
Gain = I
Pretty quiet, just a little static.
Gain II causes slightly more static.
Gain III is off the charts static.
While leaving on Gain I
IMP I slight static
IMP 0 is actually more static
IMP II for some reason is best
Gain I, IMP II seems the best with J3 at 30 and Arrow volume up all the way.
Volume J3 = 20
IMP = II
Gain = I
Once again the best settings. But still static.
The results are the same as above but greatly reduced. Id say the noise level for J3 volume 30 is a 6 and J3 volume 20 is maybe 1 or 2.
Remember Arrow Volume is cranked and the player is paused.
Then I unplug the J3. Amp is obviously still powered up. Low and behold my findings with the J3 volume 20 are about the same as the Arrow plugged straight into my headphones, no player at all.
Also I should say Im sensitive to static. I hate it!!
J3 is now on charge, Ill test more later. But with SE530 plugged into arrow, and admittedly my mini to mini also plugged in but only on the Arrow side Im hearing static.
