Ticky
- Oct 24, 2003
Headroom amps sometimes get the short shift on this forum. Which is a shame. They do make really good stuff and Headroom staff are some of the most friendly and considerate salespersons I've ever come across.
When asked for amp recommendations I frequently see people - myself included - name the Emmeline, Glimore, Meier, PPA, etc., but seldom a Headroom amp. It gives the impression that Headroom amps are either too expensive, or not up to snuff.
But when I compared the XP-7 and Corda HA-2 to my old (1996)upgraded Supreme, I had a hard time deciding which amp I prefer. One sounded better on certain music, while the other outshines the former in another genre.
I suspect that my entry level source might be a culprit, but it just goes to show that in Hi-Fi, there is a deminishing marginal return to every extra buck you shell out for the products. The HA-2 came out on top, but not by alot (we're talking inches and not yards here.) I had to listen hard and long to even rank the amps.
The lessons for me were:
1) don't underestimate the Headroom amps, and
2) amps of reputable makes in the same price range tend to sound different rather than better (relative rather than absolute).
You should audition the amps before you buy one. Granted some DIYer amps might not be available for audition, but Headroom amps, Emmeline and Meier Corda amps are. Your taste in music and sonic peference should determine which one you'll keep.
Good Luck!
Good Luck!
