Welly Wu
- May 16, 2003
HiWire:
Focus on which source component will make you happy for a few years down the road. What is it that you want from your source component? Excellent Red Book CD play back? Hi-Rez capabilities? DVD-Video? Universal format handling? Portability?
Your source component will determine to a large extent the final sound of your rig. This is especially true of headphone rigs.
Focus on the headphone amplifier later. Concentrate on the source first.
As for headphone amplifiers, be advised that the HR Cosmic is a few years old in design. There are other transportable headphone amplifiers that give it a run for its money because of updated design techniques and parts quality. One such contender is the Emmeline XP-7 with the Power Supply Upgrade. It has almost twice as much battery life, less weight and smaller size, and you can change the op-amps to suit your fancy. It is also far less than the Cosmic (Reference Module) + BS1. However, if your source is not up to par, then it is all for naught.
