Lickumms
Around $230. The Tung Sol is going to cost you $150+ and the Mullard will cost about $70.
Better yet, will it make a sizeable difference?
I am not sure if the 5998 will make a big difference of not. I know the 7236 made a pretty noticeable difference over the stock 6080. The 7236 improved the sound stage and tightened the bass up quite a bit. I would maybe start with a 7236 like a Cetron or a Sylvania. I really like the Cetron it is a great starting place for tube rolling and it a very good tube and will only put you back $40. Another option for a power tube would be 6AS7G/Russian 6H13C they are pretty cheap, less than $30, and do increase the over all tube sound.
I bought my Cetron off of eBay.: http://www.ebay.com/itm/7236-CETRON-BID-USA-NOS-Balanced-sub-for-5998-6520-421A-6080-6AS7-No-Reserve-/252572540429?hash=item3ace7f1e0d:g:dOEAAOSwCGVX2e0E
Though the biggest sound difference will come from changing out the input tube. I personally found the stock tube on the crack to be far to bass heavy and sloppy. I'm not really sure what to recommend because they all change the sound so much it really comes down to what you personal preference is. I would probably start off by buying a RCA 12au7 or any 12au7 that is around $20. Even at the lower price you will notice a pretty large difference.
For other tubes you can use check out this forum: http://bottlehead.com/smf/index.php?topic=663.0
I went ahead and purchased that CETRON tube
I have a hard time finding the right input tube on ebay. What am I looking for? NOS isn't all that important; just as long as it's tested and working well.
I mainly look for tubes that test new or at least good. Personally I would start off with a cheap good tube to see if you notice a sound difference like a RCA 12AU7 Clear Top. They are usually less that $15. It was the first tube I bought and I noticed that while it didn't change the sound sig that much it really cleaned up the bass a lot. Though your ears are different than mine and you might notice a bigger or smaller difference.
I would get something like this: http://www.ebay.com/itm/RCA-12AU7-Clear-Top-Vacuum-Tube-Tested-New-On-Calibrated-Hickok-/331979425620?hash=item4d4b840754 Or any other one that test well.
After trying out that tube, if you wanted to move up to a more expensive tube, I would maybe read some threads about different tubes and see if you can find one that may better suit your preference. Or try out different brands and models of tubes around the $20 range.
The problem I have when it comes to these things is the lack of organization. There are 100 forum pages at Bottlehead in a single thread on tube rolling. I have two kids, 8 and 12, a wife, and am very busy.
Is there an organized means of checking out my options?
