They sound similar to Grado's in that they are slightly on the brighter side and are really punchy. They differ in that they have a never ending soundstage and are EXTREMELY comfortable.
The only thing they lack is bass.
Oh the AD700s have bass. What they don't have enough of is punch in the nether regions. I found that that problem has a lot to do with the loose fit. A tighter seal will increase the bass punch some - though probably not enough for bassheads. But since the AD700s will never have that seal you'll either find their bass good enough or not. It'll come down to personal choice.
Ive also got the MS-1, I generally preffer the AD700 for what I listen to. In my opinion the ms-1 has good bass punch but it is no deeper than the AD700. I think the soundstage more than makes up for the apparant lack of bass aswell.
and the comfort, oh the comfort even on my skinny head
