Damage
- Jun 12, 2003
Quick Update:
Give the Panasonic Buds serious consideration, though the included sleeves are incredibly microphonic. They have much more forward and stronger vocals than the EX71s. If you were to consider all things being equal between the two (and they're not), the better vocal representation on the HEJ50S and their price ($10 less than EX51, $20 less than EX71/81s) makes these a serious contender.
By the by, the better vocal representation makes the trebles less harsh. Great balance overall.
However, the included sleeves are clearly more microphonic than the EX tips/sleeves. They also do not seal as well as the EX Tips. All things being equal, the EX tips and the HEJ drivers makes a good combination.
With the $20 that you saved, I'd seriously consider in investing in a set of EX Sleeves to use with the HEJs.
And yes, you can sleep on the HEJs on your side, they don't protrude as much as the EX series.
