Pars
Can Jam '10 Organizer
- Oct 28, 2003
Back to the coupling caps for the SA5.1...
I sent an email to the designer today:
I am about to replace the stock line stage coupling caps and wanted to use 1uf Dynamicaps in order to retain the shields if possible. I was a bit concerned with the frequency response issues posed by R17 of 100K ohms. Would you recommend increasing the value of R17 or is a -3dB point of 1.6Hz normally acceptable? Or do you think that using an 8uf cap here is a better solution
Reply:
The SA-5's line stage is a two-pole design with input and output coupling capacitors. Proper selection of capacitors needs to be done by loading the SA-5 into the power amplifier's input impedance (or resistor of same value) and then adjusting the poles to achieve as long a bass step as possible with as little overshoot as possible.
Goes on to explain that explaining what "bass steps" are and how to measure them is beyond the scope of this "freebie" email... OK
I've never heard of the term bass steps, but seems like a bit of BS to me? Any thoughts or illumination appreciated.
Reply:
