headphone for pda
Oct 24, 2001 at 7:30 AM Thread Starter Post #1 of 19
743
im currently using my ipaq as an mp3 player
wondering wat type of headphones i should get
preferably they should be below 100 and closed as i travel by train (which is real noisy) or go to the library quite often
also one that doesnt use an amp as i dont know much abt em and they r hard to find here in singapore
appreciate any recommendations given as i know nothing about headphones thanks
Oct 24, 2001 at 7:47 AM Post #2 of 19
I'd recommend the Sony MDR-V6/7506. $80 new for the V6, very easy to drive, closed, foldable for easier travel and they sound great.
Oct 24, 2001 at 7:50 AM Post #3 of 19
Hi,
I think the V6 might be an overkill for a PDA. It's so much bigger than the IPAQ. I think a good option might be the Koss Plugs or one of the sony wrap around phones. You don't need that good of a headphone to listen to mp3s.
Cheers
J
Oct 24, 2001 at 7:54 AM Post #4 of 19
You might want to consider these phones. I guess they would sound better than the Sony Wrap arounds but at a very good price
http://www.liquidations.com/Koss%20KSC35.htm
BTW how's the situation with regards to Anthrax like in Singapore? I heard Malaysia's pretty bad lots of scares.
Cheers
Jason
Oct 24, 2001 at 8:05 AM Post #5 of 19
Well...yeah, if it's super-portability you want then i would either go for the ksc-35s or earbuds like the mx500s or e888s. I think that the V6s will probably give you the best sound (esp. from a weak source) in a closed phone for under $100 that you can get.
Oct 24, 2001 at 8:47 AM Post #6 of 19
wow cant believe i got a response so fast thanks
i think there was an anthrax scare at the british consul next to the embassy but nothing serious so far
anyway thanks for the recommendations! now i can go look around and see which is best for me thanks guys
hopefully they're available here
Oct 25, 2001 at 1:37 AM Post #9 of 19
Yup! right on again GG!
Oct 25, 2001 at 3:39 AM Post #10 of 19
hey,
i was looking for headphones for the same exact application (mp3's through my jornada).
i tried Sony MDR-V600's, Koss KSC50's, and a pair of Sennheiser MX500's that just arrived today.
My pocket PC had a little trouble driving the 600's...maybe the IPAQ is different.
I did find that the KSC50 and MX500 were loud enough to drown out a lot of the environmental noise (traffic, etc) at a comfortable level. I returned the KSC50 after the wires started coming through the fabric cord.
i'd reccommend the MX500's...cheap ($15), and I think they sound excellent through the PDA.
Oct 25, 2001 at 3:57 AM Post #11 of 19
The MX500s sound pretty decent too! They don't have the isolation that the ex70s have and that could be good or bad, depending upon your needs.
Oct 25, 2001 at 5:46 AM Post #14 of 19
Cause they suck and they are the second worst value (read: they have the second worst price to performance ratio) in the headphone kingdom, and you can get $25 headphones that are built the smae (Koss UR-30's) that sound about the same, and you can get $20 headphones (KSC-50's, MX-500's) that sound way better....
