inseconds99
If you chose to go for the T50RPs over HiFimans keep in mind that they will require ALOT of modding to even come close to something in the $300-600 price range. You have to stuff modeling clay into the drivers and coat the inside of the ear cups in [COLOR=111111]fatmat/dynamat, among other things. If you are deadset on the TR50RPs over the HiFimans and aren't very good at DIY, or you just don't want to do it, there are Mr. Speakers Mad Dogs available for $300. They are the exact same thing as the T50RPS (only different in name), they just come pre-modded for better sound quality and have lamb leather ear pads and are pre-clayed I think as well.[/COLOR]
[COLOR=111111]If you are bass crazy also keep in mind that the Hifiman HE-400s are considered close or on par with the [/COLOR]Audeze LCD-2 ($800 cans) [COLOR=111111]in terms of bass, and the Audeze are considered the king of high quality bass. They are also easier to drive than the T50RPs, at 35 ohms vs 50 ohms, meaning you can drive them out of your ipod or w/e and they'll sound better than the T50RP. [/COLOR]
I am def not a diyer, if I were to buy those headphones is need someone to mod them for me and I might not be willing to go that far. I'd want headphones that excel in gaming like akg q701 or ad700x but with much much more bass then either of those. I need bass in my headphones, I need comfort and I need them to be great for gaming.
