it can be the dried out ear pads recovering
Good point.
the increased weight explains the base response changing too you know
Tyll and I are going to do some double blind testing to see if we can identify which 701 is "burned it" and which is not. I am also going to suggest we try to make one headphone look like the other sonically by moving the ear cups around the dummy head, adjusting clamping tension, etc. If we can make one graph look like the other this would suggest that we did not measure burn in. If no matter what we do we cannot replicate the result other than using the burned in headphone, then this would suggest the possibility we measured the process.
exactly, the drivers as from my past experiments do not change in characteristics. None, of the electrical properties apart from weakening of the magnetic field strength (which takes a LOT of time to be significant) everything remains same. Especially when modern drivers are sealed with corrosion resistant coils there is probably no electrical property (in my knowledge) which actually changes with time.
The pads on the other hands do change,
Grokit:
the increased density of the pads (from moisture) actually do affect the lower end of the spectrum (longer wavelengths) more than they do for the higher end.
Until and unless we have the technology to actually map quantitatively rather than qualitatively burn-in will remain an unsolved myth.
Gotcha, thanks. Perhaps this is due to less absorption and more reflection.
Burn-in is real, my K702 sound much better after 1000+ hours of normal usage, I use my K702 normaly for average 5 hours a day, and it's been 9 month now, the sounds open up, tonality, bass, and everything else is just better.
My 2 cents on the topic (professional headphones engineer)
- There is no point in comparing two of the same headphones as a test of identifying the effect of break in. There will always be differences between mass produced samples. Tolerances for anything but the highest priced headphones will be at least +/- 2dB across the entire frequency range. Of course you will be able to hear those differences and inter sample variation is much larger than what break in could possibly bring.
- I've yet to see any scientific proof of drivers with PET/PEEK/PU showing any sign of break-in. They don't have surrounds or spiders like regular loudspeaker drivers, which do get effected by use over time (e.g. rubber gets more compliant).
- What does change ... cushions. Leather (real or fake) gets softer and memory foam has changing properties as function of temperature. Both of those can lead to an increase in bass due to a tighter skin fit with less leakage and less "cushion bounce" leads to tighter bass. We don't really have a very scientific name for cushion bounce, but it can often show up in the low to low mid frequency range as a wiggle in the frequency response. It's essentially a whole headphone resonance (think mass on a spring). As the stiffness of the cushion changes, so does the "cushion bounce".
