DangerClose
- Feb 26, 2013
Amp + soundstage. Anything is possible especially if someone has golden ears. But I think you're looking down the wrong path if you think a different amp is going to be a big deal for the Pro 80 soundstage. The better thing would be to put different and bigger pads on, such as HM5 or 840. And even then you can only gain so much. HM5 are deeper and should help the ss more, but they may change the sound in other ways you may not like, such as a little boomier or a bump in the lower mids. And then there's the choice of pleather vs. velour. If you want more ss, velour sounds like the way to go, but you would lose isolation and bass and perhaps some "solidity of notes" then. So, trade-offs.
The "600 ohm" amp on some of those mobos or on various sound cards is marketing for what kind of headphones the amp can drive. Plenty of people complain that some of those "600 ohm-capable" amps aren't good with 600-ohm headphones. Some are.
I think Xonar says the DG is for "up to 150-ohm headphones." I could say the Xonar DG is capable of driving 250-ohm headphones because it's plenty loud for mine, (and it actually does make them sound "pretty good"), but they are still underpowering them, and they don't sound as good as they could.
Most desktop amps don't have DACs. Portable amps, some do, some don't. The Fiio product line is a good place to see the difference in how some models do and others don't. That's not necessarily a Fiio recommendation.
The M-audio has no built-in power output at all? Because the Pro 80 isn't hard to drive.
A quick read says that card has SPDIF out. If so, or just using a different output, you should be able to hook it to a home theater-type stereo receiver and then plug your headphones in to that. They're usually big and use more watts, but used ones can be dirt-cheap, or maybe you already have one. For testing purposes if nothing else.
