DoYouRight
- May 20, 2006
Justin, I was waiting on the info for the pico slim amp.
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif Yes - I am using the RCA out to feed my ALO Amphora, and the 1/8" out to feed my Nuforce Icon speaker amp - at the same time. I did discover that one bad interconnect will affect the sound of both amps, like when there is a short in the connector. |
Originally Posted by Suasexed /img/forum/go_quote.gif Okay great, thanks! As you may have noticed in the Pico Amp/DAC topic I'm considering my options on whether to get a seperate amp and DAC or have them combined. I was considering the iBasso D10 but am leaning towards this one as the feedback on Head-Fi is so positive. Does anyone know how they compare? I'm wanting to drive some HD 650s, I presume this would be up for the job? |
Stay updated on HeadAmp at their sponsor profile on Head-Fi.
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif The D10 has less voltage swing than the D10, since I think the D10 uses 5v to charge the 3.7v battery |
Originally Posted by justin w. /img/forum/go_quote.gif The Pico DAC/Amp or Amp should put out no less than twice the power, due to its 2-cell (8.4V@full charge) battery, which is needed for high impedance headphones such as the HD650 |
Originally Posted by HeadphoneAddict /img/forum/go_quote.gif The D10 has less voltage swing than the Pico, since I think the D10 uses 5v to charge the 3.7v battery, while the Pico uses 12v to charge the 8.4v battery. Since the HD600/800 is 300-600 ohms at various frequencies it needs the voltage swing to get adequate power, so the Pico will have more of that. The D10 is best with 120 ohm and less headphones. The D10 improves with better opamps as far as sonic synergy, but it will not drive the HD600 quite as well if you like powerful sound. The Pico and 3MOVE have that power, and somehow the Vivid V1 does too, but I think they use a voltage multiplier inside the V1 amp. Even the 5v P-51 is slightly more powerful with the HD600/800 than the D10. |
Originally Posted by DoYouRight /img/forum/go_quote.gif the power point makes me think that thought the D10 is a great deal, my 3move is perfectly fine |
Originally Posted by roker /img/forum/go_quote.gif For comparison purposes are there any other dacs that use the same chip as this one? I'm in between this and other dacs and the only reason I haven't pulled the trigger is because I'd like more input options. edit: the "all the dacs money can buy" thread needs to be updated. |
Originally Posted by DoYouRight /img/forum/go_quote.gif Pico dac with optical would destroy all and I would take it over anything, doubling as home and portable. |
