Headamp Blue Hawaii Special Edition
Oct 22, 2016 at 8:29 AM Post #8,476 of 9,899
  could not resist to look inside my Black blue Hawaii :wink:
Pictures posted so that you do need to open yours....
Woooo....what about Headamps warranty ?
Oct 22, 2016 at 9:12 AM Post #8,477 of 9,899
Oct 22, 2016 at 10:59 AM Post #8,478 of 9,899
@nepherte
Are the extra feet in the packing the optional rubber type?
If so, I may need to order them as well…I have the spiked feet in isolators on a glass table and my amp keeps sliding around when I plug/unplug my HP's.
  Congratulations joseph69.
Will be interesting to hear from you any difference in sound changing the EL34's.
Thank you very much!
I'm very tempted to swap out the tubes, but I would like to get use to the amplifiers signature in its stock form before doing so. But this may go right out the window very soon, and I mean very soon!
Oct 22, 2016 at 11:09 AM Post #8,480 of 9,899
Those are indeed the optional rubber ones. The metal feet are already attached to the amplifier. I ordered them to protect the underneath surface if need be (glass or wood for example). Who knows, maybe they cancel out vibrations better too. Aesthetically, the metal ones look a tad bit nicer. Though the black rubber feet match pretty well with the amplifier too I think.
Oct 22, 2016 at 11:10 AM Post #8,481 of 9,899
Nice ones.
Mine is not that clean inside, sort of dry stain / mark all over the PCB, maybe some kind of rinse aid for electronic builds that was not completely wiped out.
I also realize normal bias are quite rare
Ali
Oct 22, 2016 at 11:28 AM Post #8,482 of 9,899
Yes, they are nice looking. I had seen these feet on the silver amp (left side) in the photos below (maybe from an earlier model) and I assumed this is what I would have received if I ordered them, thanks.
Oct 22, 2016 at 12:25 PM Post #8,483 of 9,899
You can then use your metal feets with insulators like those SSC or other type.
Oct 22, 2016 at 1:02 PM Post #8,484 of 9,899
I have the metal center isolators shown in the photo above which my spiked feet sit in, just not the outer rubber pieces. So I had glued rubber sealing washers to the bottoms of my (metal) isolators, which then made it a real pain in the ass to shift the amp/PSU to my desired position due to the rubber sealing washers gripping the glass top and not being able to slide them into position, and the spiked feet kept coming out of the isolators because their not attached, their separate from the spiked feet.
So having the rubber spiked feet that @nepherte has (attached) to the amp/PSU would allow me to pick up the amp/PSU and place them where I want without  the issue of fussing with the (separate) isolators.
Oct 23, 2016 at 12:09 PM Post #8,486 of 9,899
  Simple fix for my amp sliding around when plugging/unplugging my HP's.
I placed Blu-Tack between the top of the rear back halves of the isolators and glass table top…no more issues.
A couple of photos of the GS-Xmk2/BHSE side by side.
You are a good HeadAmp's customer :wink:
Oct 24, 2016 at 10:39 PM Post #8,488 of 9,899
I used to own the exact same combo.  I sure miss my GS-X MKII & BHSE!  Just gorgeous to look at.
Oct 25, 2016 at 4:55 PM Post #8,490 of 9,899
FINALLY....I found a reliable source for a quad matched Philips holland NOS metal base :wink:
are they really better than the Mullard XF'2  or the  Holland Amperex Bugle Boy that I can also get for... half the price ?
