Headamp Blue Hawaii Special Edition
Aug 14, 2012 at 8:59 PM Post #2,327 of 9,902
the BHSE?  maybe 1 in 100 people would ask for this.  maxing out the volume control (either the RK50 or the DACT) is the same thing as not having one, psychoacoustics aside.
Thanks. Do you think maxxing out the volume would wear the parts (especially the tubes) faster than using it normally as an integrated amp or make it more prone to failures?
Aug 14, 2012 at 9:21 PM Post #2,328 of 9,902
It has absolutely no bearing on the life of the amp.
Moreover you'd then be attenuating the input signal at the source side, from the point of view of the rest of the amp circuitry nothing has changed.
Aug 14, 2012 at 10:31 PM Post #2,329 of 9,902
Exactly what nattonrice said.
The volume pot acts purely as a passive resistive voltage divider before the amplifier.
Source > Volume (Most resistance = No volume / Least resistance = Full volume) > amplifier.
Aug 17, 2012 at 1:40 AM Post #2,333 of 9,902
YAY DUDE!!!!!!!! Finally!!!!
Is that a PerfectWave DAC in the second pic?
Aug 17, 2012 at 2:38 AM Post #2,334 of 9,902
Over the last couple of days I've been leaving the power on the BHSE an hour before listening to anything and from now on that's what I'll be doing. After an hour the music seems to be more alive with better separation. l like to listen to the acoustic guitar and listening to " Summit Day" that guitar sounds close to real life, IMO I don't think or l'm not sure audio equipment will ever reproduce real life sound, but the BHSE being powered for an hour then driving the 009's to me does sound close.
Aug 17, 2012 at 3:46 AM Post #2,336 of 9,902
Those pics look nice but are the colors for real? I mean, purple leds, is that true? The BHSE looks awesome nevertheless.
Aug 17, 2012 at 3:51 AM Post #2,337 of 9,902
someone else may know the exact reason, but it must be from the photography or post processing.  the LEDs are blue like the amp.  notice whatever the black box is on the table behind the BHSE appears to have purple LEDs as well
HeadAmp Stay updated on HeadAmp at their sponsor profile on Head-Fi.
https://www.facebook.com/HeadAmp https://twitter.com/HeadAmp https://www.instagram.com/headamp/ https://www.headamp.com/ sales@headamp.com
Aug 17, 2012 at 4:14 AM Post #2,338 of 9,902
Yeah, it jumped at me, hence my questioning because it feels like a an example of HSV manipulation...
Aug 17, 2012 at 7:52 AM Post #2,339 of 9,902
turn off auto white balance. Then use a white balance card to correctly set the camera
for what the real lighting is.  CCFL lamps really cause a lot of trouble.
Aug 17, 2012 at 9:54 AM Post #2,340 of 9,902
That's probably the most likely reason, but is it possible that the camera sensor used is one that's a bit more sensitive to UV and the led's are emitting near-UV?
