MalVeauX
- Apr 29, 2011
Heya,
I'm considering picking up an HE-6.
Will a Little Dot MK III power it sufficiently?
EDIT: Update, will a LDMKIII power an HE-500?
LDMKIII Specs:
HE-6 Specs:
I can't really tell off the specs alone. Looks like 50ohm impedance, and 83.5dB sensitivity. I think the LDMKIII could do it. But I'm not at all positive.
What do you guys think? Bust? Go for it?
Very best,
LDMKIII Specs:
- SEPP (Single-Ended Push Pull) OTL in Class-A
- Frequency response: 12 hz~100 Khz (-1dB)
- THD+N: 0.15% (80 mW @300 ohm)
- Power Output:
- 350 mW @ 300/600 ohm
- 300 mW @ 120 oh
- 100 mW @ 32 ohm
- Variable Gain: 3,4,5, or 10x
- Recommended Load Impedance: 32 ohm~600 ohm
- Input Impedance: 50K ohms
- Pre-Amplifier Output Impedance: 600 ohms
- Pre-Amplifier Gain: 3-10x (also controlled via gain switches)
- Pre-Amplifier Voltage: 10V RMS
- Power Consumption: 30W (228V * 0.130A)
- Pre-Amplification circuit includes both driver and power tubes
- Driver Tubes: 2x 5654 (5725)
- Power Tubes: 2x 6H6PI (6H6n, 6H6nN)
- High quality aluminum chassis
- Dimensions (Metric): 270mm deep by 175mm wide by 123mm high
- Dimensions (English): 10.6 inches deep by 6.9 inches wide by 4.8 inches
- Weight: 3 Kg or 6.6 lbs
HE-6 Specs:
- Acoustic Seal: Open
- Sensitivity: 83.5 dB
- Warranty: 3 years
- Manufacturer Warranty: 3 years
- Headphone Type: Full Size
- Weight: 502 grams
- Impedance @ 1kHz: 50 Ohms
- Cord Length: 9ft
- Detachable Cable: Yes
- Cord Type: Straight Y
- Coupler Size: Large
- Ear Coupler Type: Full-Size
- Driver Type: Dynamic
Very best,
