Nak Man
- Aug 6, 2004
I really have no idea where the brass ring is located on the phones, is it the one that looks like a damper behind 580/600's pole piece ?
Sorry for posting pics again, but I'm sure their drivers are different, 650 have smaller 'inner' diameter:
While 580 inner ring diameter is definitely larger:
BTW this Irish 650 have exact same fine silk screen as 580. edit: Curiously, there's a number "33" etched on the dome.
Hmm ... if only that brass is the difference, it will be the ultimate tweak... Senn will send 580 driver for 650 replacement with a small instruction note - remove brass ring before installation.
Originally Posted by Tim D Also the trend seems to be that HD650 drivers 'lack' a brass ring (I also find it funny that an 'omission' turned out to be an upgrade of sorts). Maybe the part was called 'brass veil' |
