In The Absolute Sound amp reviews, the RA-1 was ranked much higher than the Max. The Grado was on a par with the McCormack and the Max was "ugly, dark and closed in". Does not sound like something that would help solve my problem with the HD600. And I'm not paying $1400 US to find that out either. |
I was actually joking about the "buy a Max" comment. While it will definitely help, it's a bit much, I know
But as for the review you mentioned, either The Absolute Sound was using a very old Max (when was that article written? Older Max's had a reputation for being a bit darker), or I have lost all respect for them as reviewers LOL. What headphones did they use? What equipment. Because to say that a Max 2001 is ugly, dark, and closed in, or even *one* of those three adjectives, is really beyond belief. The Max is not ugly, not dark, and not closed in at all. [I'm not saying that because I own one -- I'm saying that because I've heard the Max with a range of sources and a range of headphones, and it's simply preposterous.] The RA-1 is a good amp, but it is in no way comparable to a Max 2001 (except, perhaps, in some magical combination with a Grado headphone, for which it was specifically designed, and even then...). I'm saying that based on actually hearing both, not based on hearsay.
As for the HD600, you've had similar criticisms of the HD600 for quite a while; you also sound very convinced that the K501 are the absolute pinnacle of netruality and enjoyment for you. It sounds to me like the HD600 just isn't the right headphone for you? (I mean that seriously, not facetiously.)
