conanwarrior
- Nov 14, 2010
Hi everyone, I have currently been using the original cable that came with my hd 25's, but had a loose connection near the left ear.
I cut the cable and repaired with solder, worked fine for a few months, but the solder then broke, so repaired again.(because im a cheap bugger lol).
Cut a long story short, I've done this around 4 times, and think its time to actually buy a new cable instead of looking like a twazzock with a bodge job cable.
Can anyone recommend where to get a replacement cable, and should I go for the original or an upgrade cable?
Thanks, Conan.
Thanks, Conan.
