marcoarment
- Feb 15, 2014
I had this very problem with the Stax SR009. As amazing as they are, I had to use them only with music they were suited to. I now listen to a lot of music that is not "audiophile" in my car to and from work -- quite a lot of stuff that I had neglected or would otherwise. I think that is why, for example, a lot of people like the Fostex TH900s which, while not as detailed as other TOTL headphones, are "fun" to listen to music with (and hence from the Fostex/Denon FR I coined that very term).
I had the same problem with the SR-009 (during the brief period that mine worked before I had to send it in for a channel-imbalance repair): they sound amazing with amazing recordings, but anything less sounds like garbage.
FWIW, I've been renting an HE-6/EF-6 pair from The Cable Company for the last two weeks, and it has this problem much less than the SR-009 and my other flagship headphones (TH900, HD 800). The HE-6 sounds amazing on more music than any other headphone I've tried, and I actually prefer its sound overall to the 009. When it gets back from repair, I'm going to sell my 009 and KGSSHV here and go all-in on the HE-6 and a big amp instead. (Hopefully the Ragnarok.)
I also enjoy music with the HE-6 on a more emotional level than my other headphones, which I never felt with the 009 or HD 800, and occasionally feel a bit with the TH900. I wonder if this combination of factors — lower-quality recordings sounding much worse, and a lack of emotional connection — is part of what causes this "peak and losing interest" phenomenon. If you climb the wrong peak, you might achieve technical perfection poorly suited to your music or without the kind of feeling you're looking for.
But that doesn't mean it's not possible to have both. You may have picked a technical peak that's not well-suited to your taste, but there are other peaks that can sound different without being technically inferior.
