JaMo
- Feb 8, 2011
The U18 is very good as it comes with those selected higher spec Accusilicon AS338's. I recommend You to start with it as is. It sounds really good.
To really benefit from a quality Ext XO You need to have the rest of the rig on a high level and in shape and in the best of cases also use the same time pulse (Master clock) also with the dac. The fact that U18 have this, now with an even more sophisticated synthesizer for the Ext XO is a big argument to chose this DDC.
If the C16 or the C18 will push the performance further..? I don't know. Good clocks are expensive and You should aim on -118 dBc/1Hz or better. I think the C18 has -110dBc/1Hz and it will help a bit but I think You can get a better clock for decent money from AfterDark. @FredA is a good guy to ask about this.
/Jan
/Jan
