I received the following information from Gustard technical support with regard to the J35 jumper on the U16:
1.The J35 will not be eliminated.
2.The electrical function of this J35 jumper :
Mainly the frequency of the mclk signal in the iis interface, when the j35 is setting, it is 22/24 MHz, and when it is open, it is 90/98 MHz. When A20H is using input with IIS, MCLK is fixed at a frequency of 22M or 24M. Therefore, when connecting U16, you need to plug the J35 jumper inside U16.
The reference to the A20H is the Gustard A20H DAC.
