I saw that post but just realized you were using V1.61 firmware, I flashed back to V1.61 and I am using SOX to re-sample to 384khz in Jriver and success!!! Thanks for making me take a second look at that post! 384khz actually works great in windows settings also!. maybe I will be able to keep both U16's afterall...
I emailed Kingwa at Audio-GD describing my issues, so I will see what he says, below is what I sent him:
Dear Kingwa.
I purchased 2
Gustard U16 DDC's to use with my R2R-7 and R1 I2S inputs.
They both work great with I2S into my R2R-7 but I am having problems with I2S into my R1.
On the R1 (V3 Firmware) with any sample rate higher than 44hkz I get a loud static noise (only 44khz works).
On the R2R-7 I tried both Gustard U16's without any problem. (44, 48, 96, DSD, all work ok)
With the R1 I tried multiple sources (Windows 10, SOTM sMS-200, SOTM sMS-200 Ultra)
all sources had the same problem with the Gustard U16 on the R1, static with any sample rates over 44khz
I also tried turning on the synchronizer setting on the R1 but that caused nothing to work, static on all sample rates.
Do you have any advice on how to solve this? It is strange that the U16 works great on R2R-7 (V3S) but not on the R1 (V3)
Thank You
