Very well built unit, and I confirm that the stock I2S configuration works out of the box with any HDMI cables connecting into LKS004.
I am using HQPlayer and Upsampling on the fly into DSD512 via my I2S by LKS004 and it works !
So far I am able to run : Poly-Sinc-XTR-mp-2s by DSD512 which I was never able to run before with
Amanero or Xmos interface of any kinds....
Then I am even able to found DPLL10 that works for other filters, except the very heavy load! Must be my PC limitations
I can even run YouTube and online streaming out of Windows and upscaling it all to 384Khz ! Wow! Technically, this DSP has proven my theory about how important a DSP chip is, by interface and connecting between devices. It is superior to the rest.
What about that sound performances ? Awesome ! Most noticeable is that upper frequencies energy retentions. The density of upper frequencies are with great density and weight but extended well and very defined . The back ground is more quiet, with greater details retrieval, the soundstage hugely benefit and become more immersive (and this is out of the box)...crazy....and only $285 (less than any snake oil cables) LOL! But with huge benefit and real performances gains
Eventhough I have Pinkfaun I2S and OCXO clocks, that thing is only good for PCM. But if you want anything further, DSD and upscaling and so on, this is the way to go.
Usb Cables is Pangea
I2S-HDMI is Pangea
Power cord is DIY Solid Silver
Source is Built PC on board USB (no upgraded card yet)
DAC is LKS004 (Upgraded OCXO clock)
Toward Stax system T2 and 009S
