pakultra
- Mar 8, 2015
abertels,
Thank you for your advice.
Did you mean that you tried bypassing the relay by connecting those two points with a hookup wire and this did put U12 to work but it just didn't sound good because of "ground noise"?
Did you also try using a data-only cable after bypassing the relay so that there was no power or ground connected to U12's USB port at all?
By the way, 2.26 driver is out:
http://pan.baidu.com/s/1ntDUtqp
