jodokus
- Jun 1, 2007
Is it normal that the U12 stays powered on (sample rate led on), when my HTPC is shutdown?
I checked, but it's off in the bios, will check again tonight. Would you recommend keeping the U12 on, performance wise?
The Luckit 2.23 driver did not fix my issue of the U12 dropping out in the middle of playback and emitting a low-level tone. Thank goodness the tone volume is low as it is unsettling to be listening intently and all of a sudden about a 2Khz tone.
When the problem happens Windows 8.1 thinks the USB interface is normal as near as I can tell. I can see packets being shifted with USB sniffer software so the problem is further downstream of the Xmos USB interface. JRiver is running normally at the time. The U12 just locks up and requires a power cycle to restart. When the problem happens the LCD displays " - - - -". It is like the U12 or parts of the U12 just reset and do not recover.
The U12 electronics are fairly simple. There is an Altera FPGA that takes in the Xmos data output plus the two clocks, reformats, and drives the I2S, serial outputs, and front panel LCD display. I thoroughly checked the soldering on all components where I can and looks great.
I haven't given up hope as I like a challenge but it will be difficult to reverse engineer the design and figure out the issue cause. I have the U12 top cover removed and looking at signals trying to figure out how it works. I also have Xmos datasheets and reference designs as a guide. About the only thing I cannot check is the Xmos soldering as the package is a ball grid array. And forget exchanging the Xmos as I do not have the equipment to resolder BGAs. Hope you have better luck with your U12.
I suggest putting back the original 45Mhz crystal and see if the lock problem goes away.
A drop out followed by a tone or continuous clicks may be due to a glitch in the power supply causing the processor in the XMOS to crash, the Panasonic FRs you are using may have a too low an ESR for the 317 regulator, consider changing them back, 317s are very finicky around low ESR caps, the older NatSemi datasheets actually talk about it, another option is to add a 10uF Tantalum at the regulator input.
I would leave it on for performance reasons, the crystal oscillators (XOs) need 10-20mins to fully stabilize from a cold power on.
Is there any way to get the U12 to stay on without a source plugged in? I
If you are using Windows 7 and later it can enable wake via the ACPI or similar mechanism
Please create a separate thread for DYI modification of the product.
People which are not willing to do DIY just want to have reviews of the out of the box product.
It is too difficult to separate OOTB review from DYI details.
Gustard DAC-X20
http://item.taobao.com/item.htm?spm=a230r.1.14.35.1TBYRG&id=520159383364&ns=1&abbucket=14#detail
I found this on Taobao. It seems that Gustard is going to control its selling price: USD 799 (without USB input); USD 866 (with USB input)
ES9018 dual mono
