- Apr 11, 2006
Thanks for the tips. I made a custom power plan under Windows Control Panel to turn off power savings and never sleep or hibernate. This issue happens with both the PC motherboard USB ports and the preferred Jcat PCIe USB adapter. USB power is supplied by a clean +5V supply
The U12 unlocked this morning after about 30 minutes of use. Went to the Off Ramp 5 and no problem. I need to find the Luckit 2.26 driver. Their 2.23 version does not load on my PC as it is not signed correctly for Windows 8.1 even though it states that it is supported.
It may be the U12 has a fault. I restarted the PC, USB power supply, U12, and DAC but no audio output after a restart. I have USB sniffer SW and Windows thinks that it is still shifting bits to the U12 but the U12 LCD display does not show correct sampling rate. If I leave everything turned off for a while it will eventually come back. Weird and frustrating.
Hi DACLadder,
Did you remove the drivers, restart your pc, and installed the drivers again AFTER changing the XO's to Crystek ones??
I experienced some problems too with my U12 after changing the XO's to NDK's.
With my MX-U8 I had same procedure to follow,,,
Btw, you can disable driver-signing in Windows 8.1 so that you can install Luckit drivers.
http://www.howtogeek.com/167723/how-to-disable-driver-signature-verification-on-64-bit-windows-8.1-so-that-you-can-install-unsigned-drivers/
Hope this helps,
Regards,
Alex
