pakultra
- Mar 8, 2015
U12 mod final update:
Hi my friends, I've just replaced the default TCXOs with 2 NDK NZ2520SD crystals thanks to Alex's advice. The new crystals have been running for only 10 hours but I am happy with the results already. So far, I can't say the improvement is like night and day, but there are clear differences if you know what to check for. Overall, the sound is more natural and more enjoyable with the NDKs. This is particularly evident with some of my favorite test passages of songs/music that are usually difficult to do right.
Here are the NDKs that arrived in mail yesterday. They are so tiny I had to use my modded Microsoft Live Studio magnifier to see what's printed on them.
Here is how I put the NDKs into my U12:
1) Took out the TCXO's and soldered two Mill-Max 110-43-314-10-001000 gold dip14 (4 out) sockets in their place. These sockets have full 0.76µm gold contacts. The best available. These sockets will make rolling different crystals as easy as plug-and-play.
2) built pcb adapters for NDK crystals with Mill-Max 3320-0-00-15-00-00-03-0 gold pins:
3) soldered Murata GRM2195C1H103FA01D smd 0.01 uf caps to the adapters.
These capacitors are ultra accurate, have No voltage drift, negligible temperature drift and do NOT age.
4) All soldering work was done with Wonder Solder (197 degree melting point) or Chip-Quik 137 degree low temperature solder paste. This prevented NDK' performance from being degraded by possible overheating during soldering process. The blue hookup wire used is Neotech UPOCC 20 AWG Cryo Treated mono-crystal pure copper wire.
With NDKs added on top of my previous mods, I would consider my Gustard U12 modding project a full success and I am ready to move on.
Here is a full list of mods I've completed for my U12:
1) Grounded to IEC with Neotech UPOCC 20 AWG Cryo Treated 20 awg mono-crystal copper wire sourced from takefiveaudio.
2) Relay switch removed from board to stop possible power pollution of 80 mA current flowing through the board as well as to save 0.5w per hour power consumption;
3) Relay bypassed with the same Neotech UPOCC 20 awg cryo treated mono-crystal copper wire;
4) Onboard 5+ supplied to XMOS USB Vcc detection pin via a 470k pullup resistor to trick U12 into believing that it has seen USB power so that it will start communicating over USB; this mod is a must so that U12 does NOT use usb power anymore;
5) USB B socket's Vcc and Ground output pins de-soldered from board, flush-cut and insulated. This is a must so that U12 is completely and safely isolated from any USB power. It is safe to use regular USB cables with my modded U12, although data-only cable are recommended for best possible sound;
6) Coaxial transformer replaced with Murata DA101C sourced from digikey.ca;
7) Two 2200 uf capacitors replaced with ultralow impedance 2200 uf Nichicon HW UHW1E222MHD6 (14 mohm impedance) sourced from digikey.ca. These caps are better the Panasonic caps.
8) Took out TXCO's and soldered 14dip (4 out) gold sockets in its place;
9) NDKs fitted to handmade adapters and seated securely in the gold sockets;
I'd like to thank all forum members who have helped to make the mods possible. Special thanks go to hgpsemaj and Alex.
Thank you all!
Cheers!
pakultra
Capacitance | 10000pF |
Tolerance | ±1% |
Voltage - Rated | 50V |
Temperature Coefficient | C0G, NP0 |
Thank you all!
Cheers!
pakultra
