Start with that, conversion from PCM to DSD can work well if the DAC is delta-sigma based like the ESS 9038, other technologies like R2R not so much.
The caveat is you need to have a processor with sufficient 64bit floating point capability, on Intel AVX2 at least and/or CUDA floating point offload assist, min 2k CUDA cores .
This is to handle load increase of 5x, more on the complex filters like the xtr or gauss type filters.
The H26 is out riiight now!!! I wonder if it's max gain and output power is increased from the H20, which is really my only slight caveat with the H20 itself - ie: wonky gain structure and slightly limited power output through it's preamp outs.....
