GUSTARD H10 High-current Discrete Class A output Stage Headphone Amplifier
Dec 26, 2014 at 9:43 PM Post #316 of 5,561
  mine arrived today and i just got off work. my initial impressions with this amp using the hd650 and ODAC and +6db settings are very impressive! it's not as fast as using a 5998 tube but almost there. bass doesn't hit quite as hard either but almost there also. vocals aren't a bit forward as i would like but that might change with burn-in. i most likely won't post any more impressions as i have a bifrost uber gen 2 usb arriving tomorrow and later the he-560 next week. maybe later i'll test using the darkvoice 336se as a preamp after a few days.
edit: did +18 gain and much much better.
Soooo a good week ahead for you?
Look forward to hear your comparison to the Bifrost, since that's a more common DAC.
Dec 26, 2014 at 11:31 PM Post #317 of 5,561
Just a heads up to anyone with an ALO Green Line Audeze headphone cable hoping to use it with the H10. I finally managed to hook up my H10 tonight (I'm been at my parents' for Winter break). But when I tried to plug in my Paradox Slants with the Green Line, the terminator wouldn't fit since the jack is recessed between those two lips. To be fair, the ALO 1/4" terminator is ginormous. Perhaps there was a reason for making it so; just as perhaps there was a reason for making the H10's jack recessed. It blows, however, since I just got the Green Line to use with the Slants. I should have done more research. Curious to see if this is a common complaint re: the Green Line.
Dec 27, 2014 at 2:26 AM Post #318 of 5,561
Thanks for the heads up. Can you share photos of the plug and when plugged in?
Dec 27, 2014 at 3:15 AM Post #319 of 5,561
I suspect that was an oversight on Gustards' part as the space around the headphone jack is quite limited due to it's recessed location. Sorry about your misfortune but I will keep that in mind with future cable purchases. Thanks for the heads up.
Dec 27, 2014 at 10:35 AM Post #320 of 5,561
The Green Line 1/4" terminator.
The Green Line on the bottom with the Audeze stock cable 1/4" terminator.
The Green Line "plugged in".
It seems like the recessed jack is purely aesthetic. And I agree with the decision aesthetically: The recessed line across the front nicely offsets the oversized volume knob. But functionally, it doesn't seem like the best choice.
Dec 27, 2014 at 12:28 PM Post #321 of 5,561
Thanks for the pics. I can see now what the problem is. I didn't realise that the Alo plug is large. And yes, the H10 should have thought about the restriction the socket's location can create. I should be careful in buying new cables. Cheers.
Dec 27, 2014 at 2:33 PM Post #326 of 5,561
Ouch that's a total bummer. Lots of amplifiers have a bit of a recessed socket like that. I'm not sure why ALO would make such a large cosmetic sleeve. I'd reterminate that, or if you haven't before, I'd ask ALO to fix it.
You could ask them to make you an adapter, but their prices ..... wow 100 bucks for wire between two $5 connectors.... ouch
Dec 27, 2014 at 3:51 PM Post #327 of 5,561
I emailed ALO yesterday to ask if they had an alternative 1/4" termination, but haven't heard back yet. If there's nothing to be done about it, I'll have to return the cable, I suppose. Which is a shame because it seems durable, is very flexible with low memory and has good functionality. Oh well.
lol. Yeah, it's slightly ridonkulous.
Dec 27, 2014 at 3:58 PM Post #328 of 5,561
If you want to keep it, they should easily reterminate it for you to a slimmer jack. Takes less than 5 minutes to do.
Dec 27, 2014 at 4:55 PM Post #329 of 5,561
That's certainly my preference. Although I don't want to pay $100 for it. If they reterminate the one I got with the cable purchase, then we'd be green.
Dec 27, 2014 at 5:49 PM Post #330 of 5,561
Tbh, that's a hefty price for a cable. If they aren't interested in reterminating, I wouldn't hesitate to ask them for a refund. I don't see any reason for you to worry
