GUSTARD DAC-R26 Balanced Decoder R2R+1Bit Dual Native Decoding Music Bridge
Feb 28, 2024 at 10:32 PM Post #8,463 of 9,992
No doubt a matter of preference but do most lean towards using the NOS setting or keeping it off?
I don't use HQPlayer or DSD, and I definitely prefer NOS-disabled. It's cleaner to my ears. I know there's a purist idea that oversampling is bad because it's adding more processing but......we're already processing digital information, so more frequent samples is better in my world.
Feb 29, 2024 at 12:29 PM Post #8,464 of 9,992
Hello all,
I have been slowly readying through the 565 pages of posts since I go my R26 and I'm finally at the end! Feel like I know you all :)
I have been really enjoying the R26 and have recently started using HQPlayer, brings another dimension of enjoyment. I have a question though.
I have been trying out DSD, I'm fairly sure the R26 can to DSD512, but I only seem able to convince the R26 to do DSD256.
My current setup is a PC running HQPlayer streaming over a LAN to the R26 (through an FMC).
If I look at the log file of HQPlayer I see the rates that are queried from the NAA runnng on the R26, they are;
Code:
  2024/02/29 17:14:22 NAA output network format: 2822400/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 3072000/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 5644800/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 6144000/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 11289600/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 12288000/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 22579200/1/2 [dsd]
  2024/02/29 17:14:22 NAA output network format: 24576000/1/2 [dsd]
The final two rates being the DSD512 rates. I initially considered that DSD512 rates might not be available over LAN, so I tried USB and the rates weren't available via USB either.
My question is, what do you need to do to make it work?
Oh second question is, I notice that HQPlayer have just released an update to the NAA player, can that be upgraded by hand or do I need to wait for Gustard to package it up into a release?
Thanks again for all of your collective wisdom and hello!
Thanks
Rich
Feb 29, 2024 at 12:48 PM Post #8,465 of 9,992
Hello all,
Code:
Thanks
Rich
Are you sending the DSD over Dop?
If so that’s the issue.
R26 has no issue doing Dsd512 (upsampled or native)
Feb 29, 2024 at 12:56 PM Post #8,466 of 9,992
Thank you muchly that is exactly what I had done. I ticked DoP as it seemed to reduce the bandwidth over my network, I assumed some sort of alternative serialisation. I'll have to check exactly what that does, I did have a scan through the manual but didn't see it mentioned.
Thanks again.
Feb 29, 2024 at 1:54 PM Post #8,468 of 9,992
Thought I'd mention something that might be useful to others.
I bought a PI5 to see what was possible from HQPlayer embeded. It's very capable in the PCM doman, it can handle the majority of filters, including some of the more heavy filters like Sinc-L and poly-sinc-ext3 at 786k. It can't handle sinc-long that still requires a lot more grunt. DSD on the PI5 isn't an option.
If you're hapy to live in the PCM domain (which sounds great on the R26) and are looking for a low-power home for HQPlayer it's a pretty good option.
Cheers
Rich
Feb 29, 2024 at 3:35 PM Post #8,469 of 9,992
Cheers
Rich
Make sure you are in DSD direct mode and have NOS turned on with the R26.
Otherwise the R26 converts DSD to PCM once it hits the dac.
Feb 29, 2024 at 4:45 PM Post #8,470 of 9,992
Was a good call, all my voracious clicking trying to attain DSD512 I had disabled Direct DSD.
I can now spend sone time trying to understand the difference in the sound between DSD and PCM :)
Thanks again
Feb 29, 2024 at 4:55 PM Post #8,471 of 9,992
If I may offer a slightly different take, listening to DSD with DSD Direct off is one of my preferred ways to listen. As always, it feels like A Tale Of Two Sample Rates with the R26, with 44.1 and 48 tracks offering different experiences. As with my tribulations with an external clock, I notice hardly any difference with DSD Direct on or off with 48k material, and, as many here would attest, a wild hiss with DSD Direct ON with 44.1. I therefore just leave DSD Direct OFF, since it hardly matters to my ears with 48k stuff, and you sacrifice a little DSD magic on 44.1, but gain a black background, and can still enjoy an alternative to PCM. I really like the AMSDM7EC 512+fs modulator and find it presents the music with a certain texture and timbre that I just can't recreate in PCM mode, even with the same filter. I've also tried just converting everything to 48k but on my machine it stutters quite a bit.
Feb 29, 2024 at 5:07 PM Post #8,472 of 9,992
Ok but your not listening to DSD then
You are listening to PCM
The reason it sounds better is because it’s using the pcm R2R ladder and not the 1bit DSD dac
When DSD direct is off your DSD is converted to PCM by the R26
Feb 29, 2024 at 5:15 PM Post #8,473 of 9,992
Totally, not debating you there, I just find the DSD Direct hiss to be unbearable and to me this salvages some of the R26's utility. Again, I detect no difference between DSD on or off with 48k stuff that I could pick out blind 10 times out of 10, so from a listener enjoyment point of view, this is a compromise I'm happy with as opposed to just never listening to any DSD tracks or DSD processing in HQPlayer.
Feb 29, 2024 at 5:19 PM Post #8,474 of 9,992
Totally can understand that. I went the other way and traded into the A26.
Feb 29, 2024 at 7:55 PM Post #8,475 of 9,992
@xedarius & @Buckminster If you haven't yet you should try Sinc-Mx + LNS15 on PCM768, been enjoying it as my PCM setting of late. After being on poly-sinc-gauss-long per Jussi default for some time.
