Yeah I know. I'm going to try LAN, but my headphone and 2.1 setup is in my home office, and I use my PC mostly, and not just for Roon. So USB is much more convenient for me here. I have a U18 and LHY OCK-2 coming as well, so hopefully that helps a bit. Trying to find some JCAT vs Matrix H comparisons to see if the price difference is worthwhile there.
Hello,
@Aeonyx
I have installed the Element H in my PC.
However, Usb goes through with me as follows
Element H > DDC Su 2 >I2S via R26.
I used usb directly at the beginning to burn in without the I2S input and the sound had been good overall together.
I only bought the card because I had interference on the old PC.
This disappeared after installation and the overall sound opened up a bit better.
However, this had been on my old Dac, where I felt the sound was a bit cool with the Element h, which was later compensated for with the Su2.
Nevertheless, I leave the Element H in and still use it with the Su2 on the R26, although a DDC alone should actually be sufficient.
I operate the Element H with a separate power supply, which is not necessarily high-class but should be sufficient.
For all others who are still looking for a DDC Matrix Audion has brought out the Spidf 3 which is the newest DDC on the market and technologically the newest.
The price is also within reasonable limits.
@flyboibirdy
I have switched off both.
With the tube amp I get enough resolution and depth that I don't need it,although it was on at first and felt good and had a great sound,I currently have both on off.
