m-i-c-k-e-y
Meaning, from a wired/wireless network as source, it could play directly music (Tidal, Qubuz, Airplay, UPnP etc).
Apologies. I haven't dabbled in streamers or networked audio. Hard drives yes.Meaning, from a wired/wireless network as source, it could play directly music (Tidal, Qubuz, Airplay, UPnP etc).
You can download the manual from here
http://www.gustard.cn/?attachment_id=15145&download=1
It’s the chinese manual but I think it would be easy to translate with some software.
By the way It seems you own a X26 Pro. It will be great if you could share your impressions about the differences in SQ between both.
ATTENUATION When there is no independent pre-amp, the DAC is directly connected to highgain amplifier or high-gain active speakers, so it is very likely that a large digital volume attenuation (for example, -40dB) will be used to listen to music at a proper volume, which will bring big impact to the sound quality. This function is designed for this kind of application. When this feature is on, a very good analog attenuator provides a gain of - 30dB. For a global gain of -40 dB, only -10 dB digital attenuation is required when using this function. That provides a much better DNR performance.
Could you share? Thanks!Thanks! Requested and Gustard sent the manual in English.
AttachedCould you share? Thanks!
From my post on Discord today:And please, could you share your impressions about its sound? (and compared to the X26 Pro)
Yeah, I only have X26P to compare. Early days still. So far the R26 sounds pretty good with stock LCD5. By memory, less harsh than X26P. Originally first couple days it was spread out sounding and bass felt diffused and soft. After a few days, it's gotten better and more tight like the X26P. I am not a stock sound kinda guy though. The X26P is absolutely end game with convolution, EQ, HQP, Oor/Hypsos. I got the R26 out of curiosity about R2R sound and timing of launch and discovering DSD playback hiss on my X26P, not that I needed DSD, just didn't like the idea of it not working correctly. Since I needed something to use while I send it off, enter R26. After a few days it can totally replace the X26P. Differences are it is a tad more soft in bass presentation, a touch of spread out feeling in comparison and less mid forward compared to X26P.
Thanks for sharing!Attached
Do I understand correctly when I summarize that initially you thought it was OK but now as good or slightly surpassing your X26 Pro?From my post on Discord today:
Thanks for sharing!
R-2R DACs are best when left on, so their resistor networks get into a good temperature range, improving linearity.
Couple of thoughts / questions:
- How do you think the device looks in practice? From the pictures someone on ASR thought it looked like a set-top box from the 90s. I would agree.
- The clock as pictured is the same K2 as in the X26 Pro. Measurements of the latter have shown great performance, contrary to L7Audio's measurements. I wonder if the device they measured was faulty, the clock isn't quite the same, or the implementation differs so much.
- It's not clear to me whether this device is reclocking or not (and possibly upsampling like the Denafrips line-up). It's not marketed anywhere so I thought not, but there is some information to the contrary here: https://audiophilestyle.com/forums/...rd-r26-r2r-dac-x-giesemann-ocxo-master-clock/.
- I don't think that the USB interface is galvanically isolated.
- The two points above mean that this device might actually scale well with a DDC and external clock.
- I have no experience with 10 MHz clocks yet, but is it normal that it accepts both a square and sine wave? Some sort of auto-detection going on there?
- Capacitors look like Nichicon KG/KW with WIMA MKP bypass cpacitors. That's pretty high grade (though not the highest).
- Nice that the display brightness can be configured.
- Also nice that the transformers seem well split from the rest of the electronics. I wonder why there are two -- I only see one set of rectifier diodes so this may be either for load sharing, or those discrete diodes are possibly for the analog section and there might be a chip-based digital power section elsewhere.
Interesting device.
One is for analog side the other for the digital. X26pro is designed the same. Looks like they took alot of the X26pro design elements and incorporated them into the R26. Makes sense from a manufacturing point of view.- Also nice that the transformers seem well split from the rest of the electronics. I wonder why there are two -- I only see one set of rectifier diodes so this may be either for load sharing, or those discrete diodes are possibly for the analog section and there might be a chip-based digital power section elsewhere.
Interesting device.
